tosalet
Oct 19, 2015Aspirant
iPad fails to automatically change from router to Powerline wifi
I successfully installed Powerline XWNB5201 and XWNB5001 with extended wifi connection working properly with both iPad and Android phone. I then had to change the router and re-installed the Powerlin...
- Nov 02, 2015
Your solution worked, thank you. The process of doing a factory reset twice fixed it.
tosalet
Oct 23, 2015Aspirant
Hi, thanks for responding so quickly. I have the latest IOS 9.1 and no, the problem did not occur on previous software. Having said that, I have changed my router recently and setup the Powerline to the new wifi.
JamesGL
Oct 28, 2015NETGEAR Employee Retired
This might be an issue with the latest iOS update. To verify that one, you may try to connect to other wireless networks or hotspot and check if it will switch.
JamesGL
Community Team
- tosaletNov 02, 2015Aspirant
