krismu
Sep 26, 2014Follower
Is there a way to add a third AV 500 Powerline adapter to an existing pair?
I have XWNB5201 kit. One powerline adapter connected to the router and a corresponding powerline wifi access point. This access point is in my basement. I notice that my router coverage is patchy ups...
rcb30
Nov 30, 2014Novice
SamirD wrote: You would be able to do just that. Just add to the powerline network as detailed in the manual.
So would it be safe to assume I can also use a 2-port XAVB5602 as the third unit joining an existing pair of AV 500's? (This is on a different floor and other end of the house, so perhaps a little more of a risk, but want to make sure it at least theoretically should work before I buy. This 3rd area has a couple of computers that could use the help.)
