AdamBry
Oct 21, 2018Follower
Model PLP2000 (2 x PLP2000)
After setting up my Powerline 2000 + Extra Outlet I received a connection. Both of my adapters read green power, ethernet, and pick-a-plug. I noticed my mbps jumped significantly. I disabled my pre-e...
Oct 22, 2018Guru - Experienced User
I'm a bit confused on how disabling the wifi fits in, as the PLP2000 only extends ethernet, and has nothing to do with wifi. What client are you connecting to the PLP2000?
Powerline performance can be disrupted by circuit load, but the PLP2000 does have a built-in powerline filter that should minimize that.
When the connection drops, are you seeing the power led blinking green? If so, that means the PLP2000 is in power saving mode.
