roxytinker
Nov 22, 2015Aspirant
Netgear 85MBps Powerline Bridge XAV1001 compatible with xet1001 bridge
i have 2 of the netgear xet1001 bridges just wondering if they will work with the xav1001 bridges
JamesGL
Nov 23, 2015NETGEAR Employee Retired
Hi roxytinker,
XET1001 is not compatible with XAV1001. The are on different technology and is not compatible but may coexist in the same network.
- roxytinkerNov 23, 2015Aspirant
so they will work together is what im asking i have 6 other types two royal and some other ones and they all work together on same network
- JamesGLNov 23, 2015NETGEAR Employee Retired
If the main adapter connected to the router is XET and on the other end is XAV, they will not communicate as the are not compatible. In order for XAV to work, you need to have another XAV connected to the main router. So the setup should be 2 powerline adapters connected to the router, 1st is the XET for other XET devices in the network and 2nd is XAV for XAV device in the network. You may click this link for more information.
okay thanks for info as i said i have two royal adaptors two netgear xet adaptors and two other name adaoptors they are all connected to same network and all devices hooked up to them all work appricate the help
