dino68
Jan 14, 2016Follower
Netgear PLP1200-100FRS vs Netgear PLP1200-100PES
hello,im Dino,from Italy who say me the difference on this two powerline netgear? thanks for the reponses Dino
Babylon5
Jan 14, 2016NETGEAR Employee Retired
I don’t work directly for Netgear so can’t give you a definitive answer, but I’m pretty sure that the ‘FRS’ / ‘PES’ extensions are regional codes, so there could be differences if adaptor plug types / voltages for example.
A Netgear employee will probably see this and provide a more definite/correct answer.
