FattiesGoneWild
Apr 08, 2024Guide
Netgear PLP2000 mangement help
I am extremely frustrated. I want and need to verify they are setup securely. I cannot even find the ip to log in as my Nighthawk RS700 does not even show the power line adapters. Netgear also does no...
michaelkenward
Apr 09, 2024Guru - Experienced User
Could this be at all related to this conversation from a completely different user?
Re: Powerline PLP2000 management help - NETGEAR Communities
No matter, the answer is the same. There is nothing you can do to a Powerline plug that affects it security. It is essentially a dumb wired connection. The router does all the security stuff.
Read that answer for more details.
At least this question appears in the right place.
See above. The plug has no IP address.
Netgear also does not have a utility either any more.
The management utilities for other brands will work on Netgear plugs.
