Stadders1
Oct 02, 2016Aspirant
NETGEAR power line adaptors
I am hoping to set up some powerline adaptors in my home in UK.
I need 1 x adapter for the router into the downstairs ring, 1 x adaptor for the downstairs smart tv preferably ethernet or at least wired in some way to get the highest speeds. I x wireless for the kitchen tiny smart TV which is regularly moved around by the long haired boss and one upstairs on a different ring main - but routed through a single power distribution box. I have almost this set up using the old netgear AV200s but felt that It was time to speed up seriously as it takes an age to download a film on the main TV also I cannot get the old 200s any more. It would be helpful if the adaptors were pass through so that They did not use up valuable plug sockets.
Grateful for any ideas as to how I put this together. UK model numbers woukld be best otherwise I will end up with adaptors and transformers all over the place!
I cannot find out which wireless extenders are compatable with the av1200s. But that is probably because I am a little slow and confused.
Will I need some way to sort out extra filters?
We are on single phase here
Cheers
Jeremy
Stadders1 wrote:
I have almost this set up using the old netgear AV200s but felt that It was time to speed up seriously as it takes an age to download a film on the main TV ...If you can't get a decent speed to the TV with AV200, then anything faster in the way of plugs may not help.
Remember, the speed refers to the speed at which the plugs communicate over the mains circuit. When it comes to their LAN support, the old ones do "fast" (100Mbps) LAN, but newer kit has 1000Mbps.
What is your internet speed?
It looks like you want four plugs, one of them wifi'd.
Your set up is pretty well what I have. (See signature.) But my kit is AV500. The smart TV (well, BluRay player) streams just fine, with BT Infinity 1 at around 40Mbps.
I also have upstairs/downstairs. It isn't the ring that matters so much as that they come off the same fuse box. (I can actually connect to a nearby building even though it goes through a separate fused box that runs back to the same mains input.
Much to the annoyance of many people, Netgear prefers selling twin packs. You have just two options for the wifi, 500 and 1200:
Powerline Networking | Powerline Ethernet | NETGEAR UK
The choice is down to your wallet.
You can also get 1200 passthrough plugs. It isn't clear to me if these come in singles of twin packs.
Looks like you would be in for £140 at everyone's favourite high street chain.
- Stadders1Aspirant
Thanks that is most helpful. It looks like I will either go the whole hog and get 1200s or be a bit of a cheap skate and go partway and get an AV500 wifi one. What I really want is 2 ethernets, one to router and one to TV and 2 wifi, one for Amazon fire thingy in the kitchen and one for upstairs. I bought some BT AV 600s and they just do not work with the Netear sufff at all it is really annoying.
Jeremy
That's odd. They should work. I have married different makes with Netgear plugs.
The problem is that the software that different makers supply may not see "competing" kit.
