Stadders1
Oct 02, 2016Aspirant
NETGEAR power line adaptors
I am hoping to set up some powerline adaptors in my home in UK. I need 1 x adapter for the router into the downstairs ring, 1 x adaptor for the downstairs smart tv preferably ethernet or at least...
michaelkenward
Oct 06, 2016Guru - Experienced User
You should he able to use the standard "button presses" to marry the BT plugs to the Netgear one. But there is generic software out there that may see the different plugs. After all, they usually buy in their chipsets from one of the usual suspects.
Does BT supply anything?
Have you thought of visiting the BT Forum? There may be people there who know more about its hardware.
Stadders1
Oct 06, 2016Aspirant
trying BT support now but been on wait for 20 minutes. Have collaped the entire system now at home so a bit miserable. fortunately the mac is attached to the router by ethernet cable!
- michaelkenwardOct 06, 2016Guru - Experienced User
BT support is a joke.
Use the forums where fellow users are often better informed than BT's Indian call centre.
This may be the one to try:
Connected Devices & Other Broadband Discussions - BTCare Community Forums
- Stadders1Oct 06, 2016Aspirant
I gave up on them. Took the adaptors back and tried another route. Thanks for all your help.
Jeremy
