Kissel
Nov 03, 2013Initiate
Netgear Powerline Utility for Mac OS not working in Mavericks
I recently performed a clean install of OS X Mavericks (10.9) on my Mac and re-installed the Netgear Powerline Utility (v. 3.1.0.3) for Mac. Unfortunately, the utility it is unable to see my XAVB5001...
Thorium232
May 11, 2014Initiate
cemb wrote: I also found myself in the same situation. Howver by running PLC as "sudo ./PLC", it works and pulls up all of my devices. Now just to figure out how to get the launcher to run 'sudo' :)
Nice. I could fix it for good changing mode and ownership of SocketTool
$ chmod 4555 ~/Library/Application\ Support/PLC/SocketTool
$ sudo chown root ~/Library/Application\ Support/PLC/SocketTool
brucie2
Nov 15, 2015Tutor
Thanks Thorium232 your permanent fix worked beautifully. For info the utility now runs on El Capitain using this fix. Shabby of Netgear to not have updated though. Thanks also to cemb for the original fix.
