Kissel
Nov 03, 2013Initiate
Netgear Powerline Utility for Mac OS not working in Mavericks
I recently performed a clean install of OS X Mavericks (10.9) on my Mac and re-installed the Netgear Powerline Utility (v. 3.1.0.3) for Mac. Unfortunately, the utility it is unable to see my XAVB5001...
teamdude
Jun 17, 2015Initiate
How Dos!
Following on from the awesome findings you folks have had... I did the following to get this working for Mac OS X Yosemite (10.10.3) with Netgear Powerline Utility version: 1.0.0.13: -
1. Open up "Terminal"
2. cd "/Applications/NETGEAR Powerline Utility.app/Contents/MacOS/"
3. sudo ./NETGEAR\ Powerline\ Utility
Then the application played ball!
Hope this helps. http://forum1.netgear.com/images/smilies/smile.gif
tinkx
Nov 19, 2015Tutor
When I tried this, I got a password prompt, and not sure what to do at this point.
- tinkxNov 19, 2015Tutor
Sorry, hit the button too soon. I tried the account password, and got this
sudo: ./NETGEAR Powerline Utility: command not found
- JamesGLNov 22, 2015NETGEAR Employee Retired
Hi Tinkx,
Can you check the article below if this is the problem you are facing with the powerline utility?
- brucie2Nov 23, 2015Tutor
It's crucial you enter the information exactly as shown in the fix tinkx. Also be sure the utility is located correctly to start with.
Good Luck
