Kissel
Nov 03, 2013Initiate
Netgear Powerline Utility for Mac OS not working in Mavericks
I recently performed a clean install of OS X Mavericks (10.9) on my Mac and re-installed the Netgear Powerline Utility (v. 3.1.0.3) for Mac. Unfortunately, the utility it is unable to see my XAVB5001...
tinkx
Nov 19, 2015Tutor
When I tried this, I got a password prompt, and not sure what to do at this point.
tinkx
Nov 19, 2015Tutor
Sorry, hit the button too soon. I tried the account password, and got this
sudo: ./NETGEAR Powerline Utility: command not found
- JamesGLNov 22, 2015NETGEAR Employee Retired
Hi Tinkx,
Can you check the article below if this is the problem you are facing with the powerline utility?
- brucie2Nov 23, 2015Tutor
It's crucial you enter the information exactly as shown in the fix tinkx. Also be sure the utility is located correctly to start with.
Good Luck
