Kissel
Nov 03, 2013Initiate
Netgear Powerline Utility for Mac OS not working in Mavericks
I recently performed a clean install of OS X Mavericks (10.9) on my Mac and re-installed the Netgear Powerline Utility (v. 3.1.0.3) for Mac. Unfortunately, the utility it is unable to see my XAVB5001...
cemb
Jan 26, 2014Novice
cemb wrote: If you are familiar with the MacOSX Terminal utility, launch that and then change directory to the NetGear PowerLine application,
# cd /Applications/NETGEAR\ Powerline\ Utility.app
# cd Contents/MacOS/
# sudo PLC
The above assumes you have installed the NETGEAR application in your Application folder, otherwise substitute the path accordingly.
that last instruction line should read,
# sudo ./PLC
