LFloresTX
Dec 17, 2016Aspirant
NETGEAR ProSAFE GS116NA
I purchased NETGEAR ProSAFE GS116NA from Amazon.. The Cable company installed an ARRIS DG2470 Touchstone Gateway with 4 ports. When I connect my unmanaged switch to the Gateway from the Cable compa...
clithes
Dec 20, 2016Prodigy
Are you using the correct cable?
The user guide states you need a cross-over cable when connecting to a hub (page 33):
Hope this helps
- LFloresTXDec 20, 2016Aspirant
For a managed switch I would agree that you need a crossover. But this one is unmanaged so my thought was it would act as a pass through.
I'll try it and see what happens
