Annode
Jun 17, 2017Aspirant
Netgear Xwn 5001 Looses Internet connection
Hi, I'm using powerline products with 200 and 500 speed in meinem Network. The xwn5001 creates a wlan with its access point functionality using the Same Network Name as the One from my isp Router. ...
michaelkenward
Jun 18, 2017Guru - Experienced User
Annode wrote:
Hi,
Does this mean that you have two wifi sources with the same SSID?
What do the lights on the XWN5001 show when you lose connection? Is there still a link to the "host" plug?
Annode
Jun 19, 2017Aspirant
Hi Michael,
yes that's correct both devices (the router from my isp and the netgear xwn 5001) have the same network ssid. This makes it easy for the devices in the house to connect, as they automatically connect to the network with the best connection.
I've setup WIFI channels so that the isp router device is on channel 1 and the XWN 5001 is on channel 6.
The LEDs when the error appears are:
- power: green
- encryption: green,
- Wifi: blue
BR
Andreas
