ajkilpatrick
Apr 24, 2018Aspirant
New Powerline 1000 doesn't work where 2010 TP-Link model did
Hi. In our newly wired (old) house, I tested the old TP-Link powerline adapters (purchased c.2010), and they worked, that is, I was able to get an internet connection to my smart tv and watch Netflix...
- Apr 27, 2018
Thank you, Michael. I also learned that the smart tv has to be turned on, and then the internet LED lights up. All systems go now. cheers, Alison
michaelkenward
Apr 25, 2018Guru - Experienced User
ajkilpatrick wrote:
However, for the second adapter, only the Power and the Pick a Plug LEDs are lit: the Ethernet LED does not light up.
The "remote" Internet LED will not light up until you connect something to the LAN port.
ajkilpatrick
Apr 27, 2018Aspirant
- michaelkenwardApr 27, 2018Guru - Experienced User
Glad it worked out. The plugs are just trying to be "intelligent".
