Hunterc921
Jul 04, 2017Follower
No WPS button on Google router
How do you connect powerline PL1200 to Google Wifi Router that doesn't have WPS button?
clithes
Jul 10, 2017Prodigy
The PL1200 doesn't need to know anything about your router, it simply extends a LAN connection as if it was a physical cable. The device at the other end will not need to know either, as you are connecting by cable. a WPS button is only to simplify WiFi connections, which you aren't doing in this case.
Hope this helps.
