slashlos
Nov 23, 2016Aspirant
Noob rolling out several adapters
Ok, so I have an Apple Airport Extreme router; it has 3 RJ45 ports in addition to the RJ35 for a cable modem. I purchased 6 of these adapters - PL1010, as 3 pair kits, I wanted to migrate away from wifi due to interference.
I plugged one into the router, and its mate for a computer next to the PC. All is good.
Now I want to add a 3rd adapter for a TV; aside from this, do I need to plug the 4th into the router or wherever it's needed?
I had thought that these units pair each other - as they're sold in sets, so that a mate gets connected to the router, its mate elsewhere, but it seems in reading conversations, that a lone adapter at the router is all I need, and I can place others where they're needed, where they'll plug their RJ45 into the a computer. I further read that if I hit sync issues - 3rd lite on unit won't come on, mate them all locally, then distribute as they'll rememer their setup.
So do these units pair to a common or specific paired adapter ?
/los
- JamesGLNETGEAR Employee Retired
Hi slashlos,
You can only use one adapter for the router and the 3 adapter for the devices.
JamesGL
Community Team- slashlosAspirant
Hmm, that's not specifically answering my question about pairing.
Leaving adapter 1 at the hub/router, 2 at a pc, it would appear that adapters 3 and 4 could be placed at two other PCs? I think that's what you're saying?
It didn't appear so in my small test - I added a 3rd adapter to a different pc - adapter #3, and waited. Not all of its lights lit - 3rd lite specifically not lit. This led me to believe that I need to add an adapter to the hub. In this scenario, adapter are added in pairs. Maybe I didn't wait long enough?
What you're describing, and I hope you're right my experience not withstanding, is that you can add adapters once an adapter is added to a hub/router and routing *amongst( adapters will take place, so the 3rd adapter would route traffic to the 1st - the one physically connected to the hub/router, just as the 2nd adapter does to the internet.
As a corollary, locally, would adapters route between them, so PC#2 would route traffic directly to PC#3 in my scenario ?
Finally the model cannot be interered in the dialog, but all are the PL010 (1gb) model.
/los
Hi Slashlos,
Check this KB on adding additional powerline adapter.
JamesGL
Community Team
