Dean_T
Mar 27, 2020Aspirant
Pick A Plug on Powerline 1200 is green, then red when connected
When I connect my Powerline Adapter 1200 to the router and wall and whatnot, the "Pick A Plug" feature turns a steady green. However, when I connect my PC (Windows 10), it turns to red. I have used t...
- Mar 28, 2020
Problem with powerline devices is that they're sensitive to interference. Things like cell phone chargers, surge protectors, arc fault circuits, gfci outlets, high draw appliances, old/bad wiring, or even just electronics that are going bad can all create interference.
Have you tried the powerline devices both in the same room on the same circuit? If they connect that router, then its probably something within the home that's injecting interference in the power system.
Like I said, random things can do this and if you've recently moved, it could be something within the wiring causing the issue.
Mar 28, 2020Guru - Experienced User
michaelkenward
That's the first move.
But the symptoms you describe are odd.
I can't tell from your message if the network is actually working. Are there problems? Or are you just puzzled by the red light?
- Dean_TMar 28, 2020Aspirant
michaelkenward I thought they were odd too, especially after searching online for anyone else with the same problem. When I was experiencing problems the night before, I didn't check the network, so that may have been the problem. However, when I woke up this morning, the network was working fine for my family (although they are connected over Wi-Fi and ethernet), and after a bit more unplugging and plugging it just started working. So I hope it stays this way, and for now I will leave it as it is.
- jwockAug 13, 2022Aspirant
I have exactly the same problem. Blinking red/green when i connect to workstation but solid green before doing so. the download speed is terrible (10 Mbps down 20 Mbps up), and it's normally 500 down. Connected to same electrical ckt in the house as router and have same problem. Maybe faulty netgear product?
- michaelkenwardAug 14, 2022Guru - Experienced User
