Halows84
Jan 17, 2018Aspirant
pl100 powerline
I own a aircard 799s from sprint with unlimited data which is a modem and router in one. Im not able to directly connect the hotspot to my powerline direct. Is there any other way to set up a powerli...
Halows84
Jan 18, 2018Aspirant
the device is a portable aircard hotspot. There are no LAN ports to the device. It only has a micro USB port that is used to charge the device or to tether
- michaelkenwardJan 18, 2018Guru - Experienced User
Then you are probably out of luck.
The only thing I can think of is that you get a wifi repeater that latches on to the portable aircard hotspot and plug the LAN into that.
Or buy a device that does what you want.
Mobile Broadband | Home | NETGEAR
