adamsabri
Dec 01, 2018Aspirant
PL1000 Ethernet adapter not working saying Unidentified connection
Hey, for the past few weeks, my ethernet isn't working. It connects then says unidentified network and no internet access. I tried to reinstall the ethernet driver and restart pc but stil doesnt't wo...
michaelkenward
Dec 02, 2018Guru - Experienced User
Sounds like a Windows thing. If it thinks you are on a public network it will block access.
Check the Network & Internet settings.
Then Change Connection Properties. You want Private.
adamsabri
Dec 02, 2018Aspirant
Hello thank you for replying. I tried to do what you said but it didnt give me the option because it hasnt connected to it fully (becuase it says unidentified network). I tried to diagnose the problem and it said No ip can be found. I have this software called hamachi and I am not sure if that is whats causing the problem.
- michaelkenwardDec 03, 2018Guru - Experienced User
I have no idea what that is.
Try the Windows network troubleshooter.
I assume that you have checked that the LAN cable is properly plugged in.
- adamsabriDec 03, 2018Aspirant
When I do the troubleshooting it says no ip found.
This keeps coming back to a Windows issue.
Not much help I can offer on that front. It might help if you could post pictures of where you see these messages about "unidentified network and no internet access".
They look like vague messages that aren't real-world error messages.
