Isaacth
Aug 30, 2018Aspirant
PL1000 Ethernet Connection Stops Wifi Working
My PC shows i am connected via ethernet but it often does not open the internet or other internet based apps; whenever im online on my PC even if the internet is connected but not working as previous...
michaelkenward
Aug 31, 2018Guru - Experienced User
Does this mean that you have your PC connected to a router over a Powerline network?
What happens if you plug the PC directly into the router?
What is the operating system on the PC?
If it is Windows, have you tried running the network troubleshooter?
It may be that Windows thinks you are on a Public network and has blocked access to the outside world.
In Network & Internet settings you should see Network status. If you go to Change Connection Properties this should be Private.
Isaacth
Aug 31, 2018Aspirant
Yes it is through a powerline network; I've tried plugging it in directly with a 10m ethernet cable and the same happens; I'm running windows 10; the network troubleshooter says everythings ok or that www.microsoft.com is not responding sometimes; I have it set as a public network which i have now changed to private. Seems to have made it better thanks.
- michaelkenwardAug 31, 2018Guru - Experienced User
Isaacth wrote:
Yes it is through a powerline network; I've tried plugging it in directly with a 10m ethernet cable and the same happens...
Sort of rules out the Powerline plug as the source of the problem.
Exactly. Nothing to do with Powerline, simply your Windows settings.
Glad it now works.
- IsaacthSep 01, 2018Aspirant
Even with the settings on public, the problem is still occuring occasionally.
- michaelkenwardSep 01, 2018Guru - Experienced User
It should be private, not public.
As this also happens when you are not using the Powerline plug, it seems that your problem is elsewhere.
Debug Windows before you worry about the plugs.
