hcsitas1's avatar
hcsitas1
PL1000 LEDs
Is there any way to turn the LEDs off?  I can do it on my 500 via the Powerline utility but that utility won't recognize later generation PLs like the PL1000.  Will this feature be available on Genie...
  • clithes's avatar
    Feb 18, 2016
    The Genie app normally takes a little while to catch up when new adapters are launched, but I would have thought you will be able to like most of their other adapters.
    As for taping up, LEDs don't generate a great deal of heat so should be ok if you use electrician's tape, just make sure you don't close off any heat vents when doing so
