Finner15's avatar
Finner15
PL1000 No Ethernet Light
The powerline adapter I have connected to the modem shows the ethernet LED as green. However, the other adapter, the one with the antennas doesn't show any light for the ethernet LED all othe lights are lit. I tried setting them up in the same room and also tried doing a factory reset any help would be appreciated. Thank you
  • michaelkenward's avatar
    michaelkenward
    Do you have something plugged into the Ethernet outlet?
    Is the wifi active?
    • Finner15's avatar
      Finner15
      The modem is plugged in to one, but the one with the antennas doesn't have anything plugged into it. The wifi light is blue. Are there seperate names for the adapters?
        michaelkenward
        Plug something into the LAN and the light should come on. No connection = no light.
        Just the model numbers. Look on the back.
        PLP1000 is the LAN only adapter, PLW1000 is the wifi one.
