LChannell
Jan 13, 2017Aspirant
PL1200 keeps disconnecting
I Purchased 4 * PL1200 adaptors, one of them is disconnecting randomly for no given reason? It then reconnects after about 5 minutes, or if I power it off/on it reconnects again. I did see a ...
LChannell
Firstly that page has a table with no.mention of the PL1200 and is therfore out of date.
Plus nothing on that page about the devices loosing connectivity and then coming back online as I described.
michaelkenward
Jan 14, 2017Guru - Experienced User
It is the page that you get to if you start at the support pages for the PL1200
PL1200 | Product | Support | NETGEAR
It is generic advice that has nothing to do with the hardware involved. It will also apply to your more modern device.
As this is one of four plugs, have you tried swapping them around to see if it is the plug that is the problem or the mains socket it is in?
If it is the plug then you have good evidence to get it replaced under warranty. If it is the socket, then you may need an electrician.
