DMJaxun's avatar
DMJaxun
PLP1000s wont connect with eachother
Today, I woke up to find that my PLP1000s had somehow disconnected from each other overnight (they had been working about 12 hours before). I have resetted and attempted to reestablish the connection between the two and yet they are unable to connect to each other, I have tried two different sockets in my house and yet the Powerline LED will remain off. If someone could tell me what to try I would be grateful.
  • Me and my brother have swapped our receivers and it is now working, thanks for your help.
  • plemans's avatar
    have you tried them on the same electrical circuit in the house?
    Many things add interference for powerline.
    these can be:
    surge protectors
    gfci outlets
    arc fault outlets
    cheap/bad electronics
    cell phone chargers (some)
    high draw appliances
    old/poor wiring
    distance
    So many things influence powerline. Trying them on the same electrical circuit reduces the interference
