Benico
Oct 29, 2016Aspirant
PLP1200 - TV stream lag
Hi I installed PLP1200 between my internet box and my tv receveiver. It works quite fine, but I have some lags time to time. I don't know why. On TV box, I tried to change settings related to ima...
JamesGL
Oct 30, 2016NETGEAR Employee Retired
Hi Benico,
1. How far is the TV receiver from the internet box?
2. What is the speed you are getting from the 2nd adapter? To know the speed use a computer to connect to the adapter and do a speedtest.
JamesGL
Community Team
Benico
Nov 05, 2016Aspirant
Hi,
Thank you for your help.
1- TV is nearly at 2 meters, but electric cable can be longer than 2m. Anyway, all leds are green on the plug.
2- I cannot do the test simply (no laptop for this).
Can you tell me what is a good speed ? at what is the level under I can have problem ?
Kindly
Benico
- JamesGLNov 10, 2016NETGEAR Employee Retired
Hi Benico,
It is still depends on how much speed the TV can get through the powerline. You can try connecting a computer for the mean time and do a speedtest.
JamesGL
Community Team
- clithesNov 13, 2016Prodigy
Did it work ok before you installed the PLP1200 adapters? How did you have it connected before?
