Benico
Oct 29, 2016Aspirant
PLP1200 - TV stream lag
Hi I installed PLP1200 between my internet box and my tv receveiver. It works quite fine, but I have some lags time to time. I don't know why. On TV box, I tried to change settings related to ima...
Benico
Nov 05, 2016Aspirant
Hi,
Thank you for your help.
1- TV is nearly at 2 meters, but electric cable can be longer than 2m. Anyway, all leds are green on the plug.
2- I cannot do the test simply (no laptop for this).
Can you tell me what is a good speed ? at what is the level under I can have problem ?
Kindly
Benico
JamesGL
Nov 10, 2016NETGEAR Employee Retired
Hi Benico,
It is still depends on how much speed the TV can get through the powerline. You can try connecting a computer for the mean time and do a speedtest.
JamesGL
Community Team
- clithesNov 13, 2016Prodigy
Did it work ok before you installed the PLP1200 adapters? How did you have it connected before?
