pbj0995
Mar 11, 2018Aspirant
PLP1200 connection showing other devices
I have two PLP1200 powerline adapters connected to a Netgear R6300 router. I live in a condo complex and I just noticed that my neighbors PLP1200 network is attached to my router. As a matter of f...
- Mar 24, 2018
I just returned home and tried your suggestion. That seems like it did the trick. Thanks for the suggestion. I don't think I would have found that KB.
michaelkenward
Mar 12, 2018Guru - Experienced User
That's a seriously strange one. Never seen anything like it before.
Have you factory reset the plugs? This could break the links with any parasite plugs.
Can you block access in the router? Turn on Access Control and block the plugs.
The puzzle is how did their devices connect to your plugs? It is hard to get extra plugs to work with an existing network when you try. By accident seems unlikely.
How do you know that these plugs are connected to your router? What do they look like in the Network map for the R6300?
Have you tried the desktop genie? The Network map, when it works, will have separate tabs for Powerline stuff. It might give some clues as to what connects to what.
