pbj0995
Mar 11, 2018Aspirant
PLP1200 connection showing other devices
I have two PLP1200 powerline adapters connected to a Netgear R6300 router. I live in a condo complex and I just noticed that my neighbors PLP1200 network is attached to my router. As a matter of f...
- Mar 24, 2018
I just returned home and tried your suggestion. That seems like it did the trick. Thanks for the suggestion. I don't think I would have found that KB.
Mar 14, 2018Guru - Experienced User
My guess is that you are both using the default encryption key for the powerline adapter network.
Try changing yours using this procedure: https://kb.netgear.com/30785/How-to-manually-set-the-Encryption-Key-for-the-Powerline-adapter-network. That should break the link between the two networks. After you've done it, you should suggest that your neighbor also change theirs.
pbj0995
Mar 15, 2018Aspirant
Thank you for the suggestion. I will give it a try and let you know how it turns out.
