richcow
Nov 07, 2016Follower
PLP1200 ethernet cable
Could anyone tell me what type of ethernet cable is supplied with the PLP1200? I need to buy a longer one and I don't want to downgrade the set up. Many thanks
michaelkenward
Nov 08, 2016Guru - Experienced User
Anything that can handle gigabit ethernet. Nothing special. You won't notice the difference unless you buy a really cheap Chinese knock off.
