netcora
Sep 30, 2015Guide
PLP1200 in two routers.
Hello I have 2 routers one router is 192.168.1.1 and the other is 192.168.2.1 In 192.168.1.1 I have normal ISP connection and in the other 192.168.2.1 openvpn. Now I have PLP1200 powerline Adapters b...
- Oct 02, 2015No if you use the Netgear powerline utility or genie you can change the default encryption key of 'HomeplugAV' to anything you like. As a simple example you could have 2 units with a key of 'HomeplugAV1' and another two with 'HomeplugAV2' and they would coexist in the same home quite happily, but running independently of each other. To change the keys you will need to be connected by lan cable to each unit. Hope this helps
