Opers
Dec 28, 2017Aspirant
Plp1200 security
Is there any way to know if security is on? I pressed the 2 buttons I think with in 2 minuets. There is no indication so do I just trust it is engaged?
- Dec 29, 2017
I was talking about Windows programs. I should have said.
I don't think the mobile apps have that feature. My Android app doesn't help on that front. If there is a desktop program for Macs, maybe that would help.
Opers
Dec 29, 2017Aspirant
I tried the iPad version of genie and there is no power line section. I take it there is a Windows version. I'll try that later today. Thanks for the response.
michaelkenward
Dec 29, 2017Guru - Experienced User
- OpersDec 29, 2017Aspirant
Used the Windows app and found it with a padlock, so all is good. Again thanks for the help.
- michaelkenwardDec 29, 2017Guru - Experienced User
Phew. I got it right for once.
Glad it worked.
