KPersaud
Jun 26, 2021Follower
PLP2000 Adapter keep shutting down
I purchased a pair of PLP2000 Adapter and it worked for about 3 months with no issues. Lately (about 2 weeks ago), One of the Remote Adapter keep shutting down randomly (all 3 leds off). The one that...
michaelkenward
Jul 03, 2021Guru - Experienced User
What happens when you swap the plugs around? It doesn't matter which is plugged into the router. If one is overheating – quite likely in areas where the planet is in meltdown mode – then a swap will check that.
One thing to check is that "Sleep mode" is not enabled on the plugs. By default this is on.
I don't see how that can suddenly change behaviour, but you never know.
Unfortunately, Netgear abandoned its Powerline utility some time ago. The old utility doesn't work with newer Netgear plugs. So it is down to a third party utility to make this happen. The one that comes up here most often is from ZyXEL.
PL1200 and PLP1200 Powerline Utility / Netgear Gen... - NETGEAR Communities
No guarantees that this will fix tour issue, but nothing lost in trying.
