Sag167's avatar
Sag167
PLP2000. How to connect devices to its wifi?
Hello everyone,
I have just bought a PLP2000, and I would like to know how to connect pc, smartphone, etc. to its wifi.
I installed the two powerlines in 30 secs, and they perfectly worked with wires, but then, even though there is a password on both of them, it is not possible to connect to them through the wifi. I found out two devices in the wifi list, netgear70 and netgear70-5gh, but I do not know if they are the right ones. In the manual, there is not any clue about the wifi connection, while in the box is indicated wifi compliance.
Thanks in advance for any help.
Cheers,
Stefano
    • Sag167's avatar
      Sag167
      Ok, thank you.
      Why do they have a password and on the box they wrote the wifi compliance? It misled me when I bought them. I was sure to buy not only an internet powerline bridge but also a few wifi spots. :-/
      S.
      • michaelkenward's avatar
        michaelkenward
        Sag167 wrote:
        Ok, thank you.
        I don't understand "they wrote the wifi compliance".
        The password is for Ethernet network security.
