ralieghnet
Dec 28, 2020Aspirant
PLP2000 PL1200 Throughput problems
I have three power line adapter for my house. When I connect the PLP2000 by them selves I get around 800-900 Mbps durring a speed test from device to device. However, when I add into the existing powerline network the max speed I'm able to obtain is 50Mbps using the PL1200. According to what I have read and to documentation the network should be rated for 1200Mbps or the slowest device. I have tried several times to reset the network. Pairing each of the PLP2000 individually to the PL1200 and I can never get above 50Mbps on my speed test.
Here is the link I found and read while doing my reaseach
What are you plugging into the PL1200? How are you measuring the speed?
- ralieghnetAspirant
I'm plugging in to each of Plug an 8- port switch. One switch is powering my entertainment center and the other is simplying powering my POE access point. I'm using Ubiquiti switches.
Router -> Ubiquiti -> Plug (PLP2000) ----- Plug (PLP2000)-> Ubiquiti -> entertainment center
\---- Plug (PL1200) -> Ubiquiti -> POE AP
To measure speed across my network I did several different test.
1. Iperf3
2. Speedtest.net
3. Raw gopro file to/from destination
All three gave the same results within a couple of megs. It does not matter from which switch I plug into for the test. They all give the same results in any direction.
Looks a bit complicated to me. Are powerline plugs really up to feeding 8-port switches?
I have a simpler setup with a receiving plug in front of an Orbi AP. I then feed devices from the AP. If I needed more ports, I would put the switch on the AP.
