dyna962007
Sep 17, 2016Tutor
PLW 1000. How do I choose for it to use 5g instead of the 2.4. How do I shut off the wifi
The specs say its compatible with 2.4 and 5g. How do I make sure its using the 5g mode. Coming out of my router, its connected via ethernet obviouisly. My router is 2.4 and 5g capable tri band. Also...
michaelkenward
Sep 18, 2016Guru - Experienced User
Apologies, but I find your message hard to understand.
The wifi band of your router has nothing to do with the wifi bands of the powerline device.
Where do you want to turn off the wifi? Router? Powerline device?
What make and model is the router?
The Powerline device cannot communicate with your router over wifi. Both are broadcasters rather than receivers.
Have you read the manual for this device?
Powerline WiFi 1000 Quick Start Guide.pdf
