jbarem
Nov 19, 2017Follower
PLW 1010 with Netcomm NP507
Hi Im using PLW1010 (powerline 1000) at home and i have 2 other brand powerline (Netcomm NP507) i tried to use both at home but its not working (powerline 1000 connect with router and plw1010 wifi a...
michaelkenward
Nov 19, 2017Guru - Experienced User
Have you introduced the Netcomm NP507s to the Netgear plugs?
You can't just plug them into the mains and connect things. The instructions here are for Netgear plugs, but they probably work for others:
>>> Adding a powerline adapter to an existing powerline network <<<
