natbrux
May 25, 2016Follower
PLW1000 as repeater?
Is it possible to set up the PLW1000 as a repeater? Instead of having 2 networks with the same name? I can't find an option for this in the settings section. I used WPS to copy the settings from m...
- Jul 19, 2016
I bought it and connected as in the photo, it's working.
JamesGL
May 27, 2016NETGEAR Employee Retired
Hi natbrux,
The configuration for PLW1000 is different from an extender or repeater. You may need to check the installation guide.
http://www.downloads.netgear.com/files/GDC/PLW1000/PLW1000_FullIG_17Sept2015.pdf?cid=gwmng
- ErikRossJun 04, 2016Aspirant
I think that is not necessary open another topic for my question so i write here.I have read yours information on product, and I want buy this: Netgear PLW1000-100PES AC650 WiFi .
I want know, if it's possible connect the device inverted, not at the same mode of the page 7 of your link instruction, (Titled : install yours adapters).
But, connect the wifi module to the router whit ehternet cable, and next module (whitout wifi) to the other device (PS4 - Pc) whit cable.
Thanks for attention.
