natbrux
May 25, 2016Follower
PLW1000 as repeater?
Is it possible to set up the PLW1000 as a repeater? Instead of having 2 networks with the same name? I can't find an option for this in the settings section. I used WPS to copy the settings from m...
- Jul 19, 2016
I bought it and connected as in the photo, it's working.
JamesGL
May 31, 2016NETGEAR Employee Retired
Hi natbrux,
We’d greatly appreciate hearing your feedback letting us know if the information we’ve provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!
