PittMarson
Sep 28, 2016Aspirant
PLW1000 LAN access
Hi ! I bought and successfully installed a PLW1000 to extend my network with PLC. I understood later that it's not a repeater or an extender. The basic use is working fine. However, I'm t...
michaelkenward
Sep 28, 2016Guru - Experienced User
However, I'm trying to set up a peculiar LAN architecture and get stucked because devices on my main LAN can't communicate with the ones connected on the PLW1000.
Wifi connect or LAN connect?
Tell us a bit more about the rest of the network.
