PollyB
Jul 15, 2016Aspirant
PLW1000 set up - password?
I'm trying to log into my new PowerLINE WiFi PLW1000 and it is asking for a password. I must be blind, because I can't find one in the documentation or on the box where the serial number is. Anyone...
- Jul 17, 2016Never mind. I finally got a magnifying glass out and looked on the equipment again and found it. I've never seen sucha tiny font!
michaelkenward
Jul 17, 2016Guru - Experienced User
There are several current discussions with the same question:
Re: PLW 1000 the computer is asking for a password... - NETGEAR Communities
Re: PLW1000 where is the passwords? - NETGEAR Communities
Maybe one of them could help.
clithes
Jul 17, 2016Prodigy
If you are browsing to the wifi adapter using http://www.mywifiext.net/ it is simply username: admin password: password until you change it in the settings
