sean35
Sep 14, 2025Follower
PLW1000v2 - capped at 100mbps?
 Hi all.     I've been using PLW1000v2 & PL1000v2 for a while now on my home internet. I've been on a 100mbps plan & I was been getting between 70-90mbps which is fine.     I've recently upgraded to a...
CrimpOn
Sep 14, 2025Guru - Experienced User
Suggestions:
- Try new Ethernet cables. When Ethernet devices negotiate 100Mbps rather than 1000Mbps, the cause is often the physical cables.
- Temporarily move the remote Powerline device to the same room and plug it into an electrical socket on the same circuit breaker.
 Powerline is sensitive to distance, quality of electrical wiring, and passing through circuit breakers.
 If it is not clear which circuits the electrical outlets are on, temporarily connect both Powerline adapters to the same electrical outlet using extension cords.
