bananagrams
Sep 03, 2018Tutor
PLW1000v2 Wi-Fi speed rating
Hi,
Im wondering if anyone knows the actual wifi speed rating of the PLW1000v2 wifi adapter that comes in the kit? It is dual band N+AC but what are the speeds? Is it N300 + AC450 for example makin...
michaelkenward
Sep 04, 2018Guru - Experienced User
It is an answer. You just have to read what you wrote and tie the two together.
The Data Sheet for the PLW1000 says "IEEE® 2.4 GHz/5 GHz 802.11 a/b/g/n/ac wireless interface".
You can also consult the Powerline User Manual somewhere at the end of this link:
>>>> PLW1010v2 | Product | Support | NETGEAR <<<<
The "1000" refers to the wired Ethernet speed. But you knew that already.
Unfortunately, I doubt if Netgear is likely to show us the wifi speeds that it gets in its own lab tests.
bananagrams
Sep 11, 2018Tutor
FYI, it’s an AC600 access point. That is all I was trying to find out.
