CURAVEN's avatar
CURAVEN
PLW1010 Factory reset doesn't work
This worked great last night.  I changed the main default ip and now I have nothing but trouble.
I have tried (and failed) multiple times to connect to the new settings ip address via wifi.  I also can not connect via "http://www.mywifiext.net" even when connected via ethernet cable.
What other options are there to reset this to default?  What is the default ip?
  • michaelkenward's avatar
    michaelkenward
    Changed the main default IP of what?
    It is usually down to the router/modem to establish IP addresses.
    Have you set up the plugs from scratch?
    • CURAVEN's avatar
      CURAVEN
      Thanks for the reply.
      The main default ip of the PLW1010.  I believe I should be able to reach the main page with either the www.mywifiext.net page or a default ip for the device itself.
      The router has set up my internal network addresses, yes.  192.168.XXX.01 for itself, etc.  I can still access my router with this ip.
      The PLW1010 *used* to be on 192.168.XXX.17 and I changed it to 192.168.XXX.44.  And now I can not access it's main page.  I have tried to reset the device itself, with no success.
      As to setting plugs up from scrach, not really.  All the other electrical outlet plugin devices are working as before.
      I actually removed the device from my electrical outlets and plugged it into a UPS, to isolate.  I still can't get inside.  It appears to broadcast the default wifi SSID but I can't login via wifi with the default WiFi KEY nor access it by attaching my laptop with an ethernet cable to pull up the main settings page.
        michaelkenward
        What happens when you try? Remember, a factory reset will restore the old default password.
        I leave my plugs to get their IP address from the modem/router.
