Raincntry
Sep 04, 2017Aspirant
Power line 1200 not connecting
I'm having problems getting my powerline adapters to connect. The adapter plugged into my router has all three LED lights are lit when I plug The second adapter into any outlet in my house I cannot ge...
michaelkenward
Sep 05, 2017Guru - Experienced User
What do the lights look like on the second plug?
Which plugs are these? With or without wifi?
Have you reset the plugs?
The manual for some of these plugs is at the end of this link:
>>> PLP1200 | Product | Support | NETGEAR <<<
Are you adding plugs to an existing network?If so, read this:
>>> Adding a powerline adapter to an existing powerline network <<<
- RaincntrySep 05, 2017Aspirant
Thank you for your response but it was100% OE. I didn't realize that the recieving unit needed to hvee a network cable and device plugged in before all three lights woujld light up. I noticed it after I unplugged the sending unit and saw that one of the lights on the recieving unit went out. At that point I realized that it must have been gettign a signal.
Ooops.
- michaelkenwardSep 05, 2017Guru - Experienced User
If the receiving end is a wifi plug, then you do not need a cable connection.
