decksw87's avatar
decksw87
Follower
Jul 19, 2020
Power Line Adapter 2000
Alright have a powerline adpater 2000 From netgear, No matter what i do i get an unidentified network. Which cannot be set to privete in windows 10 so dont even suggest nor is the issue since other netgear powerline adapters work on the same network. Yes i dont have the other older adapters  plugged in i tried this 2000 Adapter seperately and on the same laptop that wokred with the older. Also I know the ethernet lines work comming from the router connect. All lights are green and both have been factory reset many time. Are there any other solutions than them just being faulty and replaceing them that i can try?
1 Reply
  • michaelkenward's avatar
    michaelkenward
    It is near on impossible to understand what you are talking about here.
    Take this bit.
    What is telling you "unidentified network"?
    Then tnhus:
    What does that mean?
    What cannot be set to private in Windows 10?
    Take us through what you are doing and where it goes wrong.
