Arkj's avatar
Arkj
Follower
Jan 06, 2021
Power line compatability
Hello,
I own the model quoted, I currently have 2, input and output.
I'm looking to expand my powerline net work, I dont know where to find a compatability list for my current set up.
Is anyone able to provide me with the location of a list or the list please.
  • You can mix/match powerline adapters (even between manufacturers) provided the follow the same standard. The XAV2001 was a homeplug AV1 device. You can use homeplug av2 devices with it but they're going to operate at the slowest devices speeds. Which for the xav2001 is a 200mbps device.
    read more about the home plug spec here: https://en.wikipedia.org/wiki/HomePlug
1 Reply
  • plemans's avatar
