Nicholast176's avatar
Nicholast176
Follower
May 16, 2021
Power line low speeds
I'm using my Netgear PL1000 as a device to get ethernet to my desktop. I noticed the speeds are unreasonably slow. I pay for a 300mb internet speed. My Nighthawk router is on the main floor and the 1st powerline is plugged in less than 2 ft from it. I have my other powerline on the second floor about 4 feet from my computer. If I do a wireless speedtest on my phone I get around 201 down and 11.5 up from the room that my computer is located in. typically 280-290 down next to the router and about 12 up. I don't understand why the speeds in the powerline are dropping so drastically from the powerline.
Anything helps! Thanks!
1 Reply
  • plemans's avatar
    Powerline is sensitive to interference. and many things cause interference on powerline.
    Key things?
    1. distance. if the powerline devices are on seperate circuits, the distance can be quite far. And the speeds drop with distance and extra circuit breakers.
    2. circuit breakers/outlets. arc fault, gfci, surge protectors,  and even just having seperate circuits can cause interfernce and drop speeds
    3. Old/bad/poorly wired homes cause add interference
    4. Other electronics. Cheaply made electronics can add interference. So can devices that are going bad or poorly made.
    Basically many things impact powerline. if you're hitting 200mbps over wireless, I'd stick with wireless. powerline might have a bit lower latency but hitting 200mbps covers pretty much anything you're going to do other than large file downloads. (for example, streaming 4k only takes 25-40mbps, gaming on 4k is even less)
