Paul2412
Oct 27, 2017Follower
Powerline 1000 but very slow speeds
Hi, Just installed the PL1000 and the connection works but I'm only getting about 2 mbps download. I'm using it wired. If I wired the pc with a direct connection to the router I get about 10...
- Oct 30, 2017
Hi Paul2412,
The connection depends on the electrical design of your house. The 2nd adapter maybe close to the 1st adapter but the travel of the data is a bit longer compared to the distance of the two.
JamesGL
Oct 30, 2017NETGEAR Employee Retired
Hi Paul2412,
- JamesGLNov 02, 2017NETGEAR Employee Retired
Hi Paul2412,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
