WhufcUK's avatar
WhufcUK
Powerline 1000 network?
Hi
So I have bought a pl1000 and plw1000 kit and also 2 additional wifi adapters and 2 additional Ethernet adapters.
I have set them all up as instructed but don't think they are talking to each other.
When selecting the wifi network to connect to all 3 wifi adapters appear in the list and signal strength seems to just feed off the 1st one connected.
Is there a way of making them all one network (log in to just one of them) and have good signal from all of them?
Thanks for your help.
P.s the kit was supplied by virgin media and the extras bought from amazon
  • michaelkenward's avatar
    michaelkenward
    Here's how to do it:
    >>> Adding a powerline adapter to an existing powerline network <<<
    It is also in page 8 of the manual:
    >>> PL1000 | Product | Support | NETGEAR <<<
    Remember, you only need one plug connected to the router as the host for the complete network.
    I assume that all of these plugs are powerline devices. When it comes to setting up the wifi network, you may have to be careful in choosing the SSIDs. Too many wifi sources with the same SSID can confuse the wifi clients. It can be hard to tell which one should they latch on to as you move around the place.
    • WhufcUK's avatar
      WhufcUK
      Hi
      Thanks for replying. That's what I did but they all have different wifi names/passwords. Do you have to login to all of them then or can they all have the same log in? For example the original pl extender is called netgearext13-5G and the new ones are the same but numbers 36 and 38. I want them all to be the same so the wifi is just strong on the same network all round the house.
        michaelkenward
        See my earlier reply. Also research best practice for overlapping wifi sources. Many people advocate using different SSIDs. Your call.
        The manual tells you how to set the SSID and password for each device.
        >>> PLW1000 | Product | Support | NETGEAR <<<
        You can use the desktop genie to get at each plug individually. (Use the map as described in the manual for the genie.) Or you can turn them on one at a time, change the settings, turn it off, then move on to the next one. These devices remember their settings when you turn them off.
